CNC project for my students.... help
kwertmanX3F6N
kwertmanX3F6N
I need some help on figuring out the easiest way to have students add a drawing to the fixture I have created. The design project is the traditional balsa wood CO2 car.
I am going to try using the fixture as the origin because I have found machining these cars from 4 different setups necessary. The issue is the origin or offset point gets machined away.
So I have multiple things going on here that I am trying to sort out.
The main issue is I cant figure out how to rotate the car simply once I join it to the fixture. The way the fixture works requires the car position to change pretty significantly. This also will require the students to adjust the height of the c02 car hole plug. I will attach the drawing to see what you may think is the easiest way to get kids to understand how to accomplish this.
I was also thinking that they may need to create 4 separate drawing files and then CAM them all out separate to generate code needed to machine the car.
Assume the students have a very basic level of fusion drawing skill. Thanks.
What file type do I need to use to upload an assembly on here? F3d doesnt seem to be an option for me with this drawing.
Brady_Fulton
I don't know if I fully understand the goal, but I have two possible solutions.
Easier route: Set design limitations - Only allow them to do machining from one fixture position. This will add an extra layer of problem solving and still requires post processing with other tools.
Harder route: Every student gets a chunk of 4"x4" in which they machine the negative of their car and use this to fixture each setup. More steps/skills learned, but this may be too much for this project.
kwertmanX3F6N
Thanks for the response. The main reason for machining from multiple setups is that many of the cars have pockets on the bottom that need machined for the wheels to sit inside. They also are pretty intricate to limit to one sided machining. I attached a sample of a more complex design that I have been working on machining.
