Create a trapezoidal solid
jdaues
jdaues
I want to create a trapzoidal solid. I have a sketch with 4 lines with the side dimensions which I want to then extrude. Is this the way to do it and if so what is the next step?
Hand drawn sketch and f3d file attached
jhackney1972
You should use a simple Extrude.  In the screen capture below I am Extruding on one direction, you could do it using Symmetry to keep it center on the sketch is you desire.  Sketch looks good, full constrained and on the origin.
John Hackney, Retired
jdaues
Thanks, for some reason I thought i had to join the lines to do this.
