Create A Smooth Loft
CDNGADESIGN
Message 1 of 11
CDNGADESIGN
Hello!
I am having difficulty creating a smooth loft on the attached file without weird edge lines at the transitions. I am fairly new to Fusion 360, so any assistance would be appreciated. I have included an image of what I am modeling.
Replies (10)
Message 2 of 11
g-andresen
Oh, but this is a "very suitable object" for the start with Fusion.
But the information is very sparse.
Shall we guess what you want to create where and what it should look like?
I have the impression that you should first deal with the basic tools for surfaces and bodies.
günther
Message 3 of 11
CDNGADESIGN
I suppose I should have checked to make sure I had my basic surfaces in there. I have updated and included. The issue I am having is the transition from the forward nose section to the windscreen area. I get a couple of edges that do not translate well.
Thanks!
Message 4 of 11
g-andresen
try this.
I leave the assessment of the transitions to the nose and any necessary changes to you.
günther
Message 5 of 11
CDNGADESIGN
Thanks for this, but not quite what I was looking for. I've attached a picture of the area I am trying to smooth. CL215.3 v1.png
Message 6 of 11
g-andresen
"This is fun."
Insufficient information, names in the file without explanation, and then the response that it's not what you wanted to know.
In the future, remember to create a sufficient base for solution statements.
günther
Message 7 of 11
CDNGADESIGN
I’m still very new to Fusion 360 and this forum, so patience is appreciated. I rarely reach out to the community for assistance.
Message 8 of 11
g-andresen
I took that into account in my answers.
But if a request for additional information is not complied with, there is no base for constructive assistance.
I cannot continue this question-and-answer game indefinitely.
günther
Message 9 of 11
laughingcreek
@CDNGADESIGN -read through this recent thread, which address some of the issues your running into.
https://forums.autodesk.com/t5/fusion-360-design-validate/problem-creating-a-complex-shell/m-p/96815...
for the immediate problem, the profiles for the 2 lofts that meet at that edge are both formed from a sketch.  in order to control the curvature condition of a loft that meets another loft, you have to use an edge of the surface for the profile, not a sketch.  this sometimes requires a bit of work to get the edge broken up in a way it can be used.
another thing to keep in mind is that lofting a double curve surace in the same go as a ruled surface can sometime produce sub-optimum curvature, so you may need to re-evaluate how you are breaking up your surfacing operations.
Message 10 of 11
laughingcreek
I was trying to insert this pic after the first paragragh in previous post, but the forum keeps deleting it.
Message 11 of 11
CDNGADESIGN
Thanks for this! I think it will be a big help. If I can figure this out, I'll try to post my solution.
