Create a rounded surface
Message 1 of 18
I'm trying to model a small pendant for a friend of mine, but the top needs to be rounded in such a way that the highest point is always 5mm. This is the profile I'm trying to extrude.Fox Miraculous v3.png
I'm not 100% sure how to word my problem. I guess the best way to describe what I want would be that if a path were to go from the top point around to the point where the two circles meet, and you were to look at the profiles along that path, it would be a series of half-ellipses, but each one would be slightly different based on parameters. I'm still kind of new to Fusion, so there's probably an easy way of doing this that I just don't know yet.
Replies (17)
Message 2 of 18
Does the sketch geometry in your screenshot already reflect the silhouette of the extruded geometry you hope to achieve?
Message 3 of 18
It would go upwards from that profile, rounded so that the top would meet this black line which I've drawn at roughly 5mm
Message 4 of 18
OK. I think what you may be saying is you want maximum rounding while still achieving a 5mm extrude from all important points the profile. Interesting problem. Will follow up when I have something to show...
Message 5 of 18
Is this the effect you are after?
Note that my example has radically simplified geometry so you can better understand the variable radius fillet technique.
Message 6 of 18
Here's what a constant radius fillet looks like:
Message 7 of 18
TrippyLighting
Is this the shape you are looking for ?
Screen Shot 2018-06-12 at 6.47.25 AM.pngScreen Shot 2018-06-12 at 6.47.01 AM.png
Message 8 of 18
That's exactly it yes. If you want to know it's the Fox Miraculous from MLB. How do you make that?
Message 9 of 18
Looks like I completely misunderstood. Maybe someone will still find my example useful!
Message 10 of 18
TrippyLighting
This is a T-Spline. I used the sketch a s visual guideline to create it. I started with a "notmal" cylinder and scaled it down in the Y-Axis to achieve the ellipse profile you were looking for.
Then I simply extruded, scaled and rotated the edge loops.
File is attached.
Message 11 of 18
TrippyLighting
In that case, please mark my reply as the solution.
Message 12 of 18
Can I get a screencast of what you did? As I said, still pretty new to CAD.
Message 13 of 18
TrippyLighting
Here's a screencast that shows how to o this with T-Splines. This has indeed very little to do with traditional CAD.
Message 14 of 18
Thanks for the help! Is there any way to make those edge loops snap to existing sketch geometry? Or what about if I added a series of work points along the sketch curves?
Message 15 of 18
mavigogun
I like to create bodies to snap to.   In the Sculpt environment  you can create a body representing a cross section to snap to, such as an extruded sketch profile- a tool you can dispose of retain; when attempting to conform to 3 dimensional volumes, prepare a solid body before entering the sculpt environement, then perform a Pull or Point Edit in the Sculpt workspace and Snap to Object.
Message 16 of 18
So I'd extrude out the sketch before working with the form? Then just make the body semi-transparent?
Message 17 of 18
mavigogun
Ya, transparency can be super helpful for selecting verticies or control points.   Say you were making a wing- you could extrude cross sections to snap the wing splines to.   Or you could create a cyclinder representing a bicycle head tube, freely edit the organic portions of the frame, then snap the organic frame to the cyclinder extremes.   Try it.
Message 18 of 18
I feel like I'm doing this wrong. Can you share a screencast so I can see someone who knows what they're doing?
