Create a perfect-fit stand for a model
Cadie107
Message 1 of 21
Cadie107
Hello!
I have recently 3D printed the 3D structure of a protein which I wanted to gift to a colleague who submitted her thesis about it. For that, I intended to print a stand, which I tried to design, that it perfectly fits the model.
My current approach for that is the following:
1. Extrude a stand (solid body) and place the protein (mesh->object) above it.
2. Lower the Protein in 1 mm steps and cut (combine tool) it out of the stand.
This method comes with 3 problems:
1. It's not perfect - some smaller artifacts which block the insertion can still remain.
2. It's perfect - there is no offset between the object and the cut. When I try to offset 5000+ faces, my Fusion 360 crashes.
3. It's tedious! 😉
So I wanted to ask, if anyone knows a way to better solve this issue of removing the overhanging regions in a mould.
I'll attach a screenshot as soon as my Fusion 360 comes back from freezing again (:
Thanks for every advice
Carroll
Replies (20)
Message 21 of 21
cadman777
That would be my way of doing it.
If I could make a Grasshopper script to do it, it would be wonderful.
Meanwhile, I tried this in IV2010, which was a bad idea.
The reason is b/c you have to have 100 WorkSurfaces @ 0.1mm spacing, a 2dSketch on each WS, Projected profiles in each 2dSketch (they are very intricate and some have overlapping geometry), and then Extrude/Cuts for every profile.
It's way over the top for the quantity of work involved.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
