Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Create a flat wavy surface
4 REPLIES 4
bobsprynDLZ22
1841 Views, 4 Replies
Hey there,
I'm designing an outdoor play structure, and I have surveyed the ground to account for a slope. I want to make a slope in fusion with my measurements to simulate the ground it will be sitting on.
In Maya it would have been as simple as extruding/sweeping one path along another, but it looks like all those functions in Fusion require a closed loop for the profile. Any advice here?
4 REPLIES 4
I guess, ideally I would like to sketch four connecting lines and create a plane from those, so I can control the variance at any given point.
@bobsprynDLZ22 wrote:
...but it looks like all those functions in Fusion require a closed loop for the profile. Any advice here?
Use Surface Sweep rather than Solid Sweep.
Surface Patch
Perfect. Just learned how to use that. Thanks!
