Create a draft angle
Hello!
I am on an assignment for beginners in Fusion (Introduxtion to CAD and CAE) where I have to add 10 ribs to the model and I have to make a draft angle. How do I make the draft angle in Fusion  360?
Here is the link>>https://academy.autodesk.com/node/120687/take
Looking forward to hear from you,
Franck.
LibertyMachine
This is the CAM forums, where we are focused on programming CNC cutting machines to produce physical products. I suggest asking these questions over on the Design Forum where you will likely receive the help you need for this and any other question regarding creating parts in Fusion
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
HughesTooling
Did you try the help?
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-DCA1CDE1-691D-4E17-A994-2ECF3D1E93A6
Mark Hughes
Owner, Hughes Tooling
Thanks it helps
