Create a copy of sketch and extrude new sketch under angle both in a new component
goes_sander
Message 1 of 10
goes_sander
Hi All,
I've been struggling to create a copy of an existing sketching to a new component.
And after that, creating and angle extrude of it. ( angle may be based on center point of it or some other defined point ).
But I seem to be already struggling with the first part of the process. Even copying a sketch from 1 component to a new component...
Hope some one can clarify me on the process for this. ( copying and creating an angle extrude of the sketch)
I've attached the project if some one is curious in detail.
detailed description:
I want to create a wedge in a certain angle based on the "deurbel achterplaat" component , using some parts of sketch especially the holes and form of the sketch.
Thanks all !
Replies (9)
Message 2 of 10
jhackney1972
The process of copying a sketch and placing in on an angled plane, then extruding it is covered in the video.  By the way, you should fully constrain your sketches.  I did not for the sake of time in the video.
John Hackney, Retired
Message 3 of 10
etfrench
It would probably be easier to design each part in their relative positions:
ETFrench
Message 4 of 10
goes_sander
Hi John,
Thank you very much for the explanation !
But it seems that my question wasn't clear enough. Now reading it back I see that's not clear.
What I was trying to achieve is to create a wedge backplane for the doorbell.
For example a 5 degree wedge. Now the extrusion is still a straight version of the backplate
And maybe you can elaborate a little bit more about the fully constrained part.
Seems that's I'm missing / no knowing that part good enough 🙂
Message 5 of 10
goes_sander
Oef still in a learning curve hehe.
I did get it to fit on each other within fusion 360.
But don't know how to design it relative to each other though 😄
Message 6 of 10
jhackney1972
I do not know your full intent but I will show in the video how to make an straight body, 5 degree angle base.  I will also show you what a fully constrained sketch is.  You will notice I created a new Component so it really does not matter where it is located as you will assembly it later to your other components using Assembly Joints.  Model is attached.
Message 7 of 10
goes_sander
Many thanks !
I now see what you mean with constraining part. I've got any or hardly any ....
Thanks for this video. This was indeed what I was looking for.
Creating an angle backplate for the doorbell. ( doorbell is looking too much to the sky at the moment hehe 😉 )
Message 8 of 10
goes_sander
Is there an easy way to manipulate the height of the angle extrusion?
I see that the height now depends on the offset of the plane.
Message 9 of 10
jhackney1972
I believe this is the best way.  You could Extrude it directly out from the angled sketch then place a plane across it and then use Split Body on it to create a different look model.  This will give you a different angle of the body to the top surface.  Model attached.
Message 10 of 10
etfrench
Or just draw a sketch line at the desired angle and use that to split the body.
ETFrench
