I am trying to copy a shape I have created in Sketch Mode. I right click the shape and use the menu to Move/Copy.
The create a copy checkmark is missing. Saw a forum thread from 2017 which said this was an oversight and was on a list of items to be fixed, but either it is still not done, or there is a setting which has disabled it?
Solved by laughingcreek. Go to Solution.
I think this works OK. I think you have to select something first, before the Copy button comes up. This is consistent with other Move command interactions.
Nevermind, figured it out.
I was NOT in edit sketch mode, only viewing it.
