Create 2D floor plan from 3D house model
I created a 3D model of a house:
How can I convert this to a 2D drawing, so that the dimensions of the windows and doors are also in the drawing? I'm only able to create this drawing without the dimensions of the windows and doors:
I would like to create something like this:
Thanks in advance!
Greetings
laughingcreek
do a section view of an elevation at a level that cuts thru door and window openings.
suryawa
Hi @Anonymous ,
Hope the below solution will help you to get desired output.
Commands used:
  • Section View (Then Edit Hatch to get dark borders)
  • Sketch Editor to add stairs etc
  • Text command for specifications
Amit Suryawanshi
SQA Fusion 360
rushabhthakkar_910
@Anonymous,
Create a Drawing and you can give dimensions in the Isometric view also..!!
Attaching the Model and drawing file for your reference..!!
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Bunga777
You can write doors in the sketch and make them visible in the drawing.
Here is a small sample of what I wrote.
The file is also attached for your reference.
