Crazy Colors When Opening a Drawing
neljoshua
Advisor Advisor
Message 1 of 12
neljoshua
This morning I opened a drawing to update it and check some dimensions and this is what I got:
I already had a Fusion model and another drawing open (without any issues--graphical or otherwise).  When I roll my mouse cursor over the screen, the sections that are crazy are updated, allowing me to see the drawing.
I have seen this a few times before...has anyone else?  What is going on?
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Replies (11)
Message 2 of 12
Phil.E
What does your graphics diagnostic say?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 12
neljoshua
Here it is:
[GPU Information]
GPU Device: AMD Radeon R9 M370X
GPU RAM: 2048 MB
GPU Driver API: OpenGL
[Graphics Effects Settings]
Use high-resolution graphics: Off
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Notes]
The effects could slow down the graphics rendering; try to limit them for optimum performance.
[Limit all effects to provide optimum performance]
Off
__
Message 4 of 12
Phil.E
Looks like graphics trouble.
Can you repeat this? Or was it somewhat random? Does re-starting your computer help?
If it does repeat, can you try turning off the two really heavy effects: Ambient Occlusion and Anti-Aliasing, then see if it still repeats.
Please let us know the results.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 12
neljoshua
I have seen it a number of times before, but it seems rather random.
I have not tried restarting for this issue because moving my mouse over the screen (or opening another window in front of Fusion and then going back to Fusion) gets rid of the rainbow.
__
Message 6 of 12
Phil.E
Okay, please then just let us know if turning off the heavy effects makes any difference.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 12
neljoshua
Is there a way to turn these effects off individually?  In the preferences menu, I did not see either of these options.  It appears to be all-or-nothing.
__
Message 8 of 12
Phil.E
Try the menu located in the Nav toolbar, center bottom of the screen.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 12
cmiller66
Hi Josh,
Is this happening only with drawings or have you seen it with designs too?  Do you have a secondary monitor hooked up to your Macbook?  Next time this happens can you try a window resize or Zoom Fit in the drawing and see if that clears it up?
Chris
Message 10 of 12
neljoshua
I have only seen this happen with designs.  I am using an external monitor.
I will try resizing/zooming next time I see it.
__
Message 11 of 12
neljoshua
Correction - I have only seen this with DRAWINGS, not with models.
Unrelated note: there does not appear to be a way to edit my previous post...
__
Message 12 of 12
neljoshua
I just saw this again this morning on a drawing.  I opened two drawings--one immediately after the other.  The first one loaded with the color bar pattern; the second loaded fine.
Re-sizing the window or switching applications corrects the issue.
__
