Crashing randomly
Crashing randomly
markdagraca
Crashing randomly
markdagraca
I have been having this problem for a long time now since november Fusion 360 will work for 20-30 min then it will randomly crash their is no exact way to replicate it but I have attached the error log maybe someone could diagonose the problem I have not been able to figure out what is causing it.
Feiqi.Zhang
Hi, I am sorry that you encounter this issue.  Thanks for attaching the txt file to help our investigation.  I looked at it.  It seemed to be related to some UI issue that might have caused the crashes.  When the crashes happened, did you send out Autodesk Error Report (that usually appears right after a crash happens)?  If yes, could you please let me know (my email: [email protected]) which email address you filled in the error report?  With that, we could go to our database to fetch the reports which contain much more information that will be helpful to our investigation.
Thanks.
Feiqi Zhang - Fusion 360 development team
markdagraca
