corrugate cover
corrugate cover
eng.abass5
Message 1 of 16
corrugate cover
eng.abass5
Hi ,
below I have file has 2 plates
I need to draw a wall following the corrugations  between these 2 plates
can any one show me how here or in the file ?
thanks
Replies (15)
Message 2 of 16
daniel_lyall
It would pay to try and fix your model first.
You just need to do two circles extrude it up then cut and combine
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 16
eng.abass5
how come !!
Message 4 of 16
eng.abass5
is it any thing wrong in my module ?
Message 5 of 16
daniel_lyall
Everything that is yellow and red right click on it and review the warning.
It looks like it's from stuff you have deleted
Daniel Lyall
The Big Boss
Mach3 User
Message 6 of 16
eng.abass5
yes  yes .. because I deleted some parts for size issue
I tried to draw 2 circles then extrude, cut but nothing happened.
can you show me how ?
Message 7 of 16
daniel_lyall
Sorry I cant everytime I try to do What I think will work fusion crashes hard.
It would pay to fix your model
Daniel Lyall
The Big Boss
Mach3 User
Message 8 of 16
eng.abass5
it is ok,
thank you
Message 9 of 16
jasonhomrighaus
Where are you trying to create your wall?
Are you trying to make a rim around the perimeter?
Are you trying to attach a wall to the surface?
Are you trying to fill the space between?
Create support ribs in between?
This would help a lot in understanding how to help.
Jason
Message 10 of 16
eng.abass5
i need wall with thickness 5mm around the perimeter
but fill the space between the two plates
Message 11 of 16
jasonhomrighaus
Do you need to fill the entire space between them?
Jason Homrighaus
The Watchman
C: (518)637-6601 E: [email protected]
Message 12 of 16
eng.abass5
no I need to go out round the corrugated circle 5mm and build a surface following the corrugation pattern
Message 13 of 16
jasonhomrighaus
Like this?
or like This?
Message 14 of 16
eng.abass5
first one ..
can you explain how come ?
Message 15 of 16
jasonhomrighaus
So First I used the push pull to extend your corregated plates out another 5mm.
Next I created a new ring using your sketch, that extended above and below the corrugations.
after that i combined one of the corregated bodies with the new ring body and selected to Cut the ring body.  Repeat with the second corrugated part.
you will now have 3 bodies where once you had a ring.
Ive attached your model with the 3 bodies still present.
last I created a wider circle in sketch and extruded that to cut off the excess corrugated material.  there is a little strangeness at the outside edge.
In the future, you may want to create your corrugation profile sketch somewhat larger than the final design, then you could use it repetedly to cut and parts such as the outer ring.
Message 16 of 16
eng.abass5
I am really very very thankful.
i spent a lot of time trying to solve this problem 🙂
thank you again
