メッセージ1/12
適用対象外
10-13-2016
06:07 AM
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- パーマリンクを表示
- 印刷
- 報告
Hello, as per title - I have a sketch with splines in it, then I extrudу it and create new sketch from the object's face and then I export it as dxf - CorelDraw can't open it, giving me "Unrecoverable Error" and then a data reading error. Also SolidWorks imports dxf, but skips splines. Also plugin "dxf export with polylines" doesn't help - Corel can't open it either. This problem already was mentioned on forums, but didn't find a simple solution. Is there some way to export it from Fusion directly, and if not - could you recommend some kind of simple converter, which could help. Just in case I'll attach f3d and dxf. Thanks in advance.
解決済! 解決策の投稿を見る。
