Copying Simulations To Different Configurations
jordan783ZS
jordan783ZS
I have a design that I have two "configurations" for, with two different wall thicknesses.
Previously I was manually changing between these using a user parameter, but with the new update, it seemed like a perfect way to easily have both saved in a single file. One of the things mentioned in the announcement was that it would make it easy to simultaneously do the same simulation on multiple variants of the same design.
The problem is that I have several sims set up for the default configuration, but these aren't available for the other configuration. Rather than manually recreate all of these studies, is there any way to copy a study across to another configuration or even have a single study apply to multiple configurations as was implied in some of the initial information about the feature?
henderh
Hi @jordan783ZS,
Currently there isn't a way to copy a simulation study from one configuration to another.
Adding this functionality is on our future roadmap. Stay tuned!
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
