copying custom title block from be sized to a sized
rwithrow7XLCS
rwithrow7XLCS
i recently made a custom title block on B (17in x 11in) sheet size, and am wondering if you can easily copy it to another sheet size. Preferably A (8.5in x 11in).
g-andresen
you can edit the size of the title block.
Doubleclick titleblock > Edit > from existing > move lines etc.
günther
rwithrow7XLCS
yes i can edit the existing title block but i cannot change the sheet size. when opening a new part for drawing i am given the choice to use my custom block which then makes the sheet size non-selectable, or to choose the sheet size then make a new custom title block. id rather not redo the entire title block on each sheet size which is why im looking for a kind of copy and paste function here.
g-andresen
This is how I do it:
1. I open an existing B template with my own title block (my title B)
2. with right click on this 1. template I add another one
3. under sheet settings I select the format A (e.g. portrait)
4. under sheet settings > titleblock I select "my title B"
5. double click on the title block > titlelock menue > edit title block
6. save in the template folder
günther
