cannot select circular face
j9lemmon
Message 1 of 8
j9lemmon
I inserted a DXF created in Adobe Illustrator 24 into a new design in Fusion 360, the DXF has 3 circles. Then I extruded it, and 3 holes are visible.
Now I want to want to Bore those holes, but in the Geometry tab, I can not select a circular face. Screenshot attached.
Replies (7)
Message 2 of 8
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file here?
Are you sure those are cylinders and not faceted planar faces?
Why not model from scratch in Fusion?
Message 3 of 8
j9lemmon
I've attached the requested Fusion 360 file.
I design in Illustrator because my CNC fabricator needs Illustrator files, I use Fusion 360 to create prototypes.
Message 4 of 8
davebYYPCU
Message 5 of 8
daschenbrener_0069
And any way to be able to export out of illustrator so that it does recognize the holes, or export without splines?
Message 6 of 8
davebYYPCU
I have no idea, not used it.
If you have circles in Illustrator, and sending splines to Fusion, then probably not.
Might help....
Message 7 of 8
HughesTooling
This old thread came up in my notifications recently, has a workaround. See you found it already. Guess you should raise it with Adobe as it's their problem.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 8
daschenbrener_0069
forsure, and i have, but i guess that is what the forums are for. to share real world knowledge.
Thanks for your time.
