Copying a project with linked copied projects
TomaszAdamF
TomaszAdamF
Hi
I have two projects: A1 and B1. The A1 project is used inside the B1 project. Easy.
I have a need to save and project A1 to a new A2. I have to have the old version and the new one (with special modifications) under different names.
Does anyone know the procedure how to also save project B as B1 so that the new version of project B2 is linked to project A2? As a result, I need two pairs of projects: B1 with linked A1 and B2 with linked A2.
Thanks for the help.
Regards Tomasz
HughesTooling
@TomaszAdamF wrote:
Hi
If you export project B1 you will get an fz3 file containing A1 and B1, just upload the f3z to a new project\folder and you'll get new versions of A and B.
Mark
Mark Hughes
Owner, Hughes Tooling
TomaszAdamF
Thanks a lot, Mark!
Tomasz
