Copying a pocket help.
jakenovotny
Message 1 of 8
jakenovotny
Just curious if anyone has a good idea how to copy this pocket. I was given this 6 arm spider in step file. I do not have a print. I know he wants the pockets exactly the same just one with  3 arms and one with 4 arms. I was wondering it there was a way to copy just the pocket. thanks for any help
Replies (7)
Message 2 of 8
jhackney1972
It is rather hard to try and help you without the model.  If you do not know how to attach your Fusion 360 follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
Message 3 of 8
jakenovotny
here you go
Message 4 of 8
jhackney1972
You need to try again, your model is not on your reply or on the original post.
Message 5 of 8
jakenovotny
sorry about that
Message 6 of 8
jhackney1972
You did not say how you wanted to handle the hole.  If you want it in the pattern, it can be added easily.  Three and four arm version are attached.
Message 7 of 8
jhackney1972
Attached are the same models WITHOUT the cross leg holes.
Message 8 of 8
jakenovotny
Thank you Sir!!!
