Copy sketch to another design.
david_hansson_23
david_hansson_23
Hello! new to Fusion 360 and anything CAD related.
I've designed some parts that I want to laser/water cut and while designing them I realized that one part, which is smaller, fits exactly inside another bigger part. Lining them up so that they cut simultaneously would save some material and time.
I therefore figured it would be nice to copy the sketch for the small part to the sketch for the large part but I seem unable to do this.
What I tried to do was to open the design for the small part, enter edit sketch mode, mark the entire sketch (click and drag mark) and pressed ctrl + C. Then I opened the design for the larger part and entered edit sketch mode, pressed ctrl + V but nothing gets pasted.
I will upload pictures of the parts to visualize what I want to move and where.
The first picture shows the smaller part, which is 30x52mm
The second picture shows the larger part, which has a 30x60mm gap in the middle where the smaller part fits.
 I hope I can get some answer about this, thanks in advance! 🙂
/David
HughesTooling
Here's a link to a tips thread about copying sketches between documents.
http://forums.autodesk.com/t5/post-your-tips-and-tutorials/copy-sketch-between-documents/td-p/595488...
The key is you need to select something in the destination sketch, the origin for example then the paste option shows in the menu.
Mark
Mark Hughes
Owner, Hughes Tooling
david_hansson_23
Thank you! I had not selected anything in the destination sketch.
