copy paste origin
copy paste origin
copy paste origin
If I copy paste the origin one point is created, I'm able to move the copied point in space orthogonally on the xy plane and vertical on z axis (my up vector is z).
If I deselect the just copied point and I select move that point has screen oriented axis. Very curious...:)
regards
innovatenate
Autodesk Support
Autodesk Support
Could you record a screencast of the behavior? It sounds like the Move command traid is not oriented to XYZ, is that correct?
Nathan Chandler
Principal Specialist
