Hi there, im new and first sorry for my englisch.
I have a simple question, when i move an object and before i "x" little checkbox that says "copy" in the side menu, i can easily copy an object. But when i then change the size of the original object, also the copy does the same. is there a way to unlock this behavior so they are both "self standing" objects, where i can make changes at the original object without effecting to the copy? I also tried instead of copying Objects to build components and copy the, but there it is somehow the same. Maybe if it is not to much, a little screen recording video would help...
About help i would be very happy, thank you,
Tim
Solved by HughesTooling. Go to Solution.
If you use a component then use Paste New you get an independent copy. The copy will have its own features in the timeline so edits will be easy.
Mark Hughes
Owner, Hughes Tooling
