Copy faces from converted STL mesh
fusion360EBTBT
fusion360EBTBT
I am trying to update an STL file. I imported and converted the stl mesh and cleaned it up a bit. Now I am trying to copy a portion of it to make it longer however I cannot seem to be able to copy the faces to duplicate the pattern.
In the attachment you can see the extruded "tail" and now I want to extend the indents down the extrude. (Original STL from here: https://www.thingiverse.com/thing:4372958). Here is the file link if someone was wanting to look: https://a360.co/3JuUjXU
jhackney1972
Your link Fusion 360 file is not available.  One of two things causing this are: 1. You forgot to allow Download in your Shared Link or 2. You are using a Fusion 360 Personal license which does not allow for Sharing File links for download.  The best way to to simply attach you model to a Forum post reply.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
Warmingup1953
I also couldn't make a pattern via Faces so I created Tool Bodies to Cut and patterned those tool bodiesScreen Shot 2023-03-12 at 4.44.01 pm.pngScreen Shot 2023-03-12 at 4.42.54 pm.png
fusion360EBTBT
Yes, I have the personal license... I did not realize this was a restriction. Attaching
Bunga777
表面のコピーを使用する際の参考として、添付のビデオを参照してください。
fusion360EBTBT
Thank you @Bunga777, this was exactly the answer and so simple. I do appreciate you taking the time to review and record the process. You are awesome.
