Copy Component to new Design Component gets Very Big
pittsallen
Message 1 of 8
pittsallen
Hello Fusion Forum,
When I copy a Component to a new Design, Save as Mesh
and open it In Bambu to slice the Component has become
very big.
I have checked to the Units in the Save as mesh to
make sure I am not going from MM to inches but
it continues to balloon when opened in the slicer.
Thanks.
Allen Pitts
Replies (7)
Message 2 of 8
TheCADWhisperer
@pittsallen
Can you attach the *.f3d file and the resulting *.stl file for testing?
Message 3 of 8
pittsallen
Hello Cad whispere and Fusion forum,
Files attached.
Allen Pitts
Message 4 of 8
TrippyLighting
We need the original file with design history in .f3d or .f3z format.
Message 5 of 8
pittsallen
Hello trippy, cad whisperer and the Fusion forum,
The STL file format is part of the problem. The clamp was
downloaded from Thingiverse via a search for C-clamp by
KerryBG.
So am trying to save the STL as a 3FD but when I save it Fusion
makes it like twenty-five times the correct size. Perhaps it was saved
at Thingiverse in inches and the units in my Fusion is mm.
Will try that when I get back to my computer.
Allen Pitts
Message 6 of 8
pittsallen
Went to Thingiverse and copied a fresh copy of the clamp STL. The
STL was opened in Fusion and in Document Settings the units
were changed from mm to inches.
The file still is giant, see Copy_Component_260320.jpg, attached.
A couple of weeks ago the clamp was printed and the
size, as shown attached JPG C-clamp_260321.jpg was
about four inches. Now when I open up the STL
in Fusion is 24 inches.
What made it grow?
Thanks.
Allen Pitts
Message 7 of 8
TheCADWhisperer
@pittsallen wrote:
 Document Settings the units were changed from mm to inches.
1. Start a new file and verify that the units are mm.
2. Insert, not Open.
(view in My Videos)
Message 8 of 8
lauri_barnhart
Hi @pittsallen,
Did the info from @TheCADWhisperer help answer your question?
If it did, it’d be great if you could click the "Accept Solution" button so others can easily find it too.
If you’re still needing more help, feel free to share an update here. The community will be happy to jump in with any next steps to help you get where you need to be.
Best,
Lauri | Community Manager
