Copy bodies and sketches from one file to other?
jeffmorris
Message 1 of 8
jeffmorris
Is it possible to copy bodies and sketches from one file to other? I searched this forum and I think it's not possible.
Replies (7)
Message 2 of 8
JHRendon
It is possible. right click on the bodie
and in the file you want the bodie, right click on the name
For sketches is different. Right click on the sketch and edit it.
Select the sketch and right click on it
In the design you want that sketch, create a new sketch. right click and paste. (keyboard command works too)
and there is your sketch. you can move it whereever you want. Just click on ok and that's it.
Message 3 of 8
laughingcreek
The methoid @JHRendon showed for copying bodies id for copying an entire component, not for individual bodies.  everything in the component will copy that way (bodies, sketches and construction features).
it's not always convenient to copy the entire component.  You can also use the derive feature to bring in individual bodies and sketches from a model if you don't want to copy the entire component.
Message 4 of 8
Rushikesh.kadam
@jeffmorris another way to copy a sketch from one file to another can be done using DXF.
1. Right-click the sketch to copy.
2. Select Save as DXF and save it.
3. Now in the file where you want a copy of the sketch select Insert> Insert DXF.
4. Select the plane for the sketch and the DXF file created in step 2.
The sketch will be copied and you can also edit it in the target document, independent of the sketch in the source document.
Rushikesh Kadam.
If my reply was helpful, please click the "Accept as Solution" or the “Like” button. This helps others to find the answer more quickly!
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 8
shahriarsifat1802164
As mentioned this technique earlier, I also prefer this,
Insert DXF | Fusion 360 | Autodesk Knowledge Network
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 6 of 8
laughingcreek
@Rushikesh.kadam
I was floored to see a AD employee suggest converting a perfectly god native fusion sketch into a DXF, and back into a native fusion sketch, in order to move it from one model to another.   Given the known issues with curve importation, the lose of information (ie, constraints of any kind) and the degradation in curve quality, such a suggestion being given to a new user (who will be back to get help "fixing" their now mangled sketch) is almost criminal.
Message 7 of 8
Rushikesh.kadam
@laughingcreek Thank you for bringing up the point. I missed mentioning the conditions for using the DXF sketch. As other methods to copy a sketch were suggested in the thread just wanted to add another option. But definitely should have had mentioned the limitations. Thank you for bringing it up.
Rushikesh Kadam.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
Message 8 of 8
oldrebelworkshop
Wonderful. Easy to follow and has saved me loads of time. Great solution to problem.
