Message 1 of 8
Copy as saves with additional geometry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I am designing an assembly, I like to use the Copy As function to save the component as a standalone drawing for manufacturing. I noticed the Copy As file is not the same as the original file with additional holes and sketch geometry not found on the same part in the assembly. I have done it several times with the same results, Construction planes, additional extrudes and sketches. The only was to copy the same part is to delete the capture history of the entire assembly and then save the component. When I do this I get the same part in both drawings. Any idea what is causing this to occur?
