- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The site search is horrible and google returns a few hits but nothing specifically about how to copy/move/whatever a 'cut.'
I want to mill a round recess cut in a plate, and place an object in it. I 'cut' a cylinder recess into the plate, and added the object body. Cool.
That's fine but I also need to step/repeat it.
The FIRST option I mentioned in the title above, I found -no- way to 'select a cut' in order to copy it. The impression I get is that a cut is an 'un-object' in that it's invisible except in the context of the object its's cutting. When I turned off visibility for the plate I could see the cut, and ctl-c, but ctl-v said no object selected (because I had to turn off visibility for the plate to see the cut - Catch-22.)
OK Plan-B. I changed the cut to a body. That's a separate part and I can happily copy/paste them anywhere. But, I can't find a way to change it back to a cut.
One or both of those processes should be possible, but I've got a wrong step. I don't care which one I use as long as it works.
I don't want to cut all the recesses separately because I'll definitely need to move them again later anyway as various 'ctrl-click' selections. Also, it's faaaaar easier to create a new identical object relative to the original, rather than count all the little mm tic marks to the new location.
In the timeline I see options for Selection Set and Group but can find pretty close to zero documentation about those.
