Copper brake pipe run - curve through points?
sean.kerslake
sean.kerslake
So in Creo I would create a curve though a 3d point cloud (one for each intersect point) with the options straight lines with rads at each vertex, then use it as a sweep trajectory. Not seeing anything that elegant in Fusion? Looks like a plane for each bend radius with a tangential line running off it to the next plane and bend radius with some fun and games to decipher the position of each intersect point?
Any other suggestions?  Cheers
davebYYPCU
If you have preexisting reference points,
Turn on 3d sketching,
Use Project > Include to collect them into current sketch, and connect to them, otherwise,
Use the triad controls to make next point alignments.
Might help....
