Copies of components with separate configurations...
FMWfablab
FMWfablab
Hi all!
I am looking to making a bit register for my CNC drawer. The bits come in 18mm or 13mm boxes. I have 77 of them. I would like to make an even pattern across the entire panel but not every hole will be cut the same. Is it possible for me to make a configuration for each option that gets copied in a rectangular/symmetrical pattern that allows me to choose either 15mm or 18mm for each instance? I've created the configuration but so far whenever I change the configuration option, it changes all instances instead of the one I have selected.
gautham_kattethota
@FMWfablab
By definition, pattern creates instances/copies of the original geometry. If you change one of them, all of them end up changing because there is only one underlying definition.
A workaround you could try, which is a bit more laborious as you cannot use patterns, is to insert the configurations individually into another document.  Then you can control what each inserted instance points to.
Regards
Gautham
Gautham Kattethota
Software Development
