Copied component won't Joint.
brad.bylls
Message 1 of 8
brad.bylls
I have created a component and then made a Move/Copy that component.
I then want to create a joint for both components.
It will let me joint the original component but not the copy.
Am I missing something when copying?
Brad Bylls
Replies (7)
Message 2 of 8
davebYYPCU
Not enough information.
Did you Paste New?  Jointing both components, to another?  Themselves?
Might help....
Message 3 of 8
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Message 4 of 8
jhackney1972
I am guessing you accidentally had Body selected, for your Move Object, in your Move Copy.  This will create a new body instead of a component which will only allow a one way Joint.  Video will show this.
John Hackney, Retired
Message 5 of 8
brad.bylls
Sorry.
I created the original component.
I then used the move/copy command in the Solid>Modify menu to make copy of
the original.
Then I used the Joint command to constrain the original component to a
point.
That worked just fine.
When I tried to constrain the copied component, I couldn't even select it
to create a joint.
Brad Bylls
Message 6 of 8
jeff_strater
please show your workflow with a video or screencast.  I've never seen a case where a copied component cannot be selected for a joint.  Are you certain that you are copying the component and not the body, as @jhackney1972 suggested?
Jeff Strater
Engineering Director
Message 7 of 8
brad.bylls
OK
Didn't see that it was on bodies.
Changed to component and it works just fine.
Thanks for the help and sorry for the trouble.
Brad
Brad Bylls
Message 8 of 8
brad.bylls
That was the problem.
Brad Bylls
