Hi! I have been printing a number of cookie cutters and this is my first that will not print properly. The bottom layer prints well, but the cutter does not adhere to the base. Do you see anything wrong with the file attached? Thanks so much for your time and support.
Try adding a chamfer between the cutter wall and the base.
This was done by projecting the cutter wall to a sketch, offsetting that, then filleting the acute angles.
ETFrench
