Converting a fusion 360 file to either a .BRD or a .s3d
Message 1 of 9
Hi Guys.
Anyone know if this can be done ?
Malcolm
Replies (8)
Message 2 of 9
TrippyLighting
Would you have some more information on these formats, perhaps in the form of links ?
Message 3 of 9
PhilProcarioJr
I believe .brd are PCB designs and .s3d is a game format file......could be wrong though.
Anyways there isn't going to be an easy way to get these formats from Fusion 360.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 4 of 9
TrippyLighting
Yes, I work with Eagle and it uses .brd as the extension for the board files. However that and a game format woud be a wierd combination of formats to ask for in one sentence 😉
Message 5 of 9
PhilProcarioJr
I think shape3d uses both of these formats.
Either way your not going to export either of these formats from Fusion no matter what app they are for. Smiley Wink
The real question here is what import files are supported by the other app and does Fusion export to any of them.
Phil Procario Jr.
Message 6 of 9
PhilProcarioJr
@TrippyLighting
This comment:
"I believe .brd are PCB designs and .s3d is a game format file......could be wrong though."
Was meant as a joke to illustrate that without the proper info it's hard for us to help. Smiley Wink
Phil Procario Jr.
Message 7 of 9
Hi Guys .
Sorry if there was not enough info ,
Yes it is to export to shape3d , but problem is solved now .
Many thanks
Malcolm
Message 8 of 9
Malcolm,
I got the same problem (exporting models from Fusion 360 to Shape3D) and found this thread, could you help me by providing more info on how you solved it?
Eduardo
Message 9 of 9
HughesTooling
If I've found the correct Shap3d you can import igs if you have the import option.
https://www.shape3d.com/Products/ImportOption.aspx
Mark
Mark Hughes
Owner, Hughes Tooling
