Convert splines to arcs
Hi
Currently imported a DXF file from a customer and the profile of the part has been created by splines, the trouble I'm  having is when the DXF file is saved to cut on our laser machine the spline lines are not shown on the laser cutting path.
Any help on how to convert the spline lines to arcs would be much appreciated.
Regards Aaron.
TrippyLighting
If you go to the Fusion 360 App store, you'll find a DXF spline to poly line plugin.
Thank you for this information.
I've just downloaded and installed the DXF spline to poly line plugin.
Tried to use the feature but I keep getting the pop up below when trying to convert.
Do you have any advice what I'm doing incorrect ?
Regards Aaron.
g-andresen
are you in active Sketch mode?
günther
Hi
Yes I'm in edit sketch mode.
All working now thank you
Regards Aaron
