NPT Threaded hole options missing
flatout3d
flatout3d
In this example I have tried (with and without a modeled pre-drilled hole) to get a 1/8 - 27 NPT tapped hole on the end center of the part without success. The only option I see is for a 1/16 NPT and all the standard options are not there. Is this a bug or a limitation in the product or am I missing something?
MRWakefield
Have you tried selecting 1/8" in the size drop-down? 😉
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
flatout3d
Thanks for the reply, this is very unusual, when I select the size option ( which I had done before I posted) I see no response as indicated in the 1st screen shot below. If I grab the feature edit panel and drag it up then the pulldown list of values is displayed. Is this a bug?
It is not until the bottom of the feature edit panel is further away from the window edge by what the size drop down list needs that it will then display the list of options.
I was curious and tried a several of the display pulldowns positioned along the bottom of the interface and non-of these show options when used, in the screenshot below I have clicked on the drop down and nothing displays. If I make Fusion windowed and not full screen then the drop downs show. This has to be a bug? Are there any setting or workarounds I can use? If it is a bug how can I report it?
MRWakefield
Ooh yes, that certainly looks like a bug to me! Perhaps @jeff_strater  might be able to log this as a bug or maybe bring it to someone's attention that can.
Marcus Wakefield
Phil.E
Hi I cannot reproduce the bug you describe. Can you make a video with screencast or some other means?
When the hole dialog is near the bottom of the screen, the size list opens upwards.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
MRWakefield
I hadn't checked the behaviour @flatout3d reported in his/her last post but now I have I'm getting the same behaviour as you are, i.e. the drop-down opens upwards.
Marcus Wakefield
