Convert spline to polylines : problem
I try to export a sketch into DXF. This sketch has polylines, which disappear when I open the DXF in Inkscape.
I have read that it is normal, and there is a workaround : opening the DXF in QCAD ( https://forums.autodesk.com/t5/fusion-360-design-validate/splines-removed-when-saving-as-dxf/td-p/57... ) and export it in another DXF format.
This workaround don't work well, and it still bugs in spline.
I installed the Fusion 360 plugin "converting splines to polynes". But it is not the same interface that here : https://apps.autodesk.com/FUSION/en/Detail/Index?id=4611814297957846949&appLang=en&os=Win64
The only window have one choice : "conversion tolerance" (mm). I have not the choice of "number of section to split lines into", and the DXF in output dont have polylines. Do i wrong things ?
Sorry for my english, i am not sure that you can understand me Man Embarassed
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am sorry to hear about the difficulties! Can you post your .f3d file from Fusion here? I would love to test around and see if I can get it to work in Inkscape. I have done a few projects now in Fusion and then pushed it into Inkscape that contained splines and had it work so I'd be curious to see whats going on.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
g-andresen
I have tried a lot:
1.  The export via save as dxf transfers only lines
2.  With the spline to polyline plugin I get an unclean curve, which has to be reworked and hardly corresponds to the original.
3.  I now use a workaround with a 360.
Here is my way:
1.  Create sketch in top view
2.  Share public link
3.  Download as dxf (A360)
4.  Open in QCAD > Perfect spline
I hope it helps
günther
etfrench
@James.Youmatz: I've run into the same issue with the Dxf to polyline addin.  It no longer has a dialog to set the number of segments.  Can this addin either be fixed or removed from the store?
ETFrench
Thank you for your answers.
My method :
- In fact, the plugin Spline to polyline has not the label "number of sgements" but it's work ( under the label "conversion tolerance"). It convert well Spline to Polyline. If i try to open DXF without this plugin, neither QCAD or Inkscape can read all the splines.
- open the DXF in QCAD (Inkscape can't open it correctly)
-  save the file as a "R15 DXF"
- and Inkscape can now read the file.
I have join the f3D files in atachments. The only faces concerned is : hautcote2_2
