@hg1027 wrote:
...Why would it be preferred method, if the projected line isn't really part of the sketch?...
of course projected lines part of the sketch. it's usually preferred to not break the link b/c it references some other geometry that you want it to be linked to. this is a BIG part of parametric modeling.
...I want to offset a projected curve and then extrude that area. I can't use that projected curve or any offset based on it as either side of an extrusion. ..
projected lines that are on the sketch plane can be offset. lines, projected or not, that are in 3d space cannot.
and if your offsetting a spline (projections that aren't straight lines or an arcs will be splines), you probably don't want to offset them anyway. for some reason the curvature quality tends to degrade in fusion. for that you want to offset a surface.
