- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everybody !
I present you my problem : I would like to convert a mesh into a surface.
The initial file's format is PLY, but I can't open it with Inventor or Fusion 360. With other software that I have, I can convert it into : STL or OBJ.
If I convert it in STL, I could see it : it is tri-mesh. When I use the tool "Convert" there is a message "Warning too many triangles...". I have seen two explications in this forum :
- "Convert" does not work very well with tri-mesh : so I turn it to Quad-mesh, but it does not work more...
- This is because it is a STL file and fusion 360 do not like STL files, and it is better to use STP.
I have the same problem with OBJ.
So, in my dashboard, when I try to export the STL (or OBJ) to STP, it does not work too... In fact, it works but it is an empty file... And I receive a pdf "Warning your file was empty".
I have a student licence, so maybe that is why, but I found nothing about this. Is it impossible to export a format in another one or to convert into surface with a student licence ?
Do you have any idea about what should I try to solve my problem ?
Thank you a lot for your help !
