Convert .edrw to dwg
Message 1 of 12
Hi John,
Could you please explain how to convert a .edrw file to .dwg with Fusion 360?
Many thanks and best regards,
Paola
This post was moved from the AutoCAD LT Forum
Replies (11)
Message 2 of 12
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the Fusion 360 forum. Welcome to the Autodesk Community!
 I am not  sure how to best convert the edrawing file from Solidworks to a dwg or other format that AutoCAD/LT can utilize.  Do you have a file to share that I can examine?
John Vellek
Message 3 of 12
Hi John,
Many thanks for your prompt reply!
I am asking you this as I saw your comment in another thread.
I attach here the file I'd like to convert to dwg.
Thanks and best regards,
Paola
Message 4 of 12
john.vellek
Hi @Anonymous,
The attachment is not in your last post. Please put it in a ZIP file and attach it again but do not do this through email as it will not work.
John Vellek
Message 5 of 12
Hi John,
Sorry. Please find the file attached as ZIP.
Many thanks.
Paola
Message 6 of 12
john.vellek
Hi @Anonymous,
Since the EDRW file is basically for viewing, there is not much that can be done with it.  Here is a site that details what you can do with such a file.  With the viewer from Solidworks you can export to a variety of graphic formats but they are all raster based. If you can work with this you should be set to go. If you need a fully 2D or 3D vector drawing you will need to ask the Solidworks user to export the model to a DWG.
If you have a raster to vector conversion program or know how to do this in something like InkScape or Adobe Illustrator then you should be able to get a 2D drawing file.
John Vellek
Message 7 of 12
TheCADWhisperer
@Anonymous wrote:
... with Fusion 360?
How much experience do you have with Fusion 360?
Message 8 of 12
Hi John,
I saw in another thread your reply saying that with Fusion 360, .edrw files can be converted to dwg:
https://forums.autodesk.com/t5/autocad-lt-forum/convert-edrw-to-dwg/m-p/6437132/highlight/true#M1411...
I haven't used Fusion 360 before at all.
Anyway thanks for the help.
Paola
Message 9 of 12
I have zero experience with the software for now.
I asked because I saw it in an another Forum thread as a possible solution.
Now it is ok, I don't need to do the file conversion anymore.
Best,
Paola
Message 10 of 12
hello,
I am a newbie here. I would like to convert some of my files from Word to PDF. And now looking for a software or something like that. Can you help me?
Thank you!
Message 11 of 12
TheCADWhisperer
@Anonymous wrote:
... I would like to convert some of my files from Word to PDF. ..
Adobe Acrobat
Save Word as pdf.
Message 12 of 12
I thought I need tools to do that. Anyways, I searched and found few websites which offer such kind of services. I would like to share one of it https://pdf2word.io/ Are those websites helpful?
Please let me know. I am bit confused about what to try. Thanks!
