Convert and Pull malfunctioning.
6 REPLIES 6
360taiphi
290 Views, 6 Replies
Good day,
I was working on the following exercise:
https://f360ap.autodesk.com/courses/designing-with-a-mesh/lessons/lesson-1-convert-and-pull
However, whenever I try to Pull the vertices to the Mesh Body, the body that was converted disappears entirely and does not reappear at all. I have to convert it again each time but that is how far I can go.
This is what I am working on:
https://a360.co/2PctcCZ
Any assistance would be greatly appreciated.
T. Phillips.
6 REPLIES 6
laughingcreek
in reply to: 360taiphi
I opened your file and tried it.  seems to be working ok for me.  can you screen cast what your seeing?
360taiphi
in reply to: laughingcreek
Ok,can you explain how to screen cast?
360taiphi
Ok I figured it out, I will send it to you.
TrippyLighting
Please see this thread.
360taiphi
Ok, it seems to be working now, I don't understand why it was happening before. Thanks for your time and patience though. If it happens again I will let you know.
T. Phillips
360taiphi
in reply to: TrippyLighting
Excellent! Thanks man!
