convert a mesh body to a solid body using a personal use license?
Pylonbob
Message 1 of 26
Pylonbob
Is there any way that I can convert a mesh body to a solid body using a personal use license? I know that I can get the paid for version but I only use Fusion to make things that I give to charity.
Replies (25)
Message 2 of 26
g-andresen
yes!
günther
Message 3 of 26
TrippyLighting
Not all meshes are created equally, so @g-andresen method may, or may not work.
In any case it is often the least preferred method.
If you can share the mesh file or even a screenshot, we can provide much better feedback.
Message 4 of 26
Pylonbob
Hi, thanks for replying. What I am trying to do is alter the head by putting in two circular eye sockets 12mm Dia and 1mm deep so I can then stick in two eyes. If I stick them straight on to the printed model it's harder to get them exactly right. When I convert the mesh to solid I still have all the triangles which is harder to design on to. I believe that the paid for version there is a way to make it one solid object by selecting prismatic but for that it tells me that I have to have the paid for version.
If I can't do what I want using Fusion is there any other software that I can use?
Message 5 of 26
TrippyLighting
That would indeed  be the wrong workflow
@Pylonbob wrote:
... I believe that the paid for version there is a way to make it one solid object by selecting prismatic but for that it tells me that I have to have the paid for version.
That would also be the wrong workflow.
What I would do is to create two spheres with the solid modeling tools in Fusion.
Then I'd change to the mesh tab and tesselate the two spheres. Still in the Mesh tab I'd then combine/cut the tesselated spheres with the imported mesh.
Done!
Message 6 of 26
Pylonbob
Hi, I tried your suggestion but couldn't get it to work, I still had mesh triangles and not a solid surface to work on so I used the hole command on a point on the surface and that allowed me to roughly cut in the size and depth that I wanted. Thanks for your help.
Message 7 of 26
TrippyLighting
You did not follow my instructions 😉
If you can provide the model, I can demonstrate it.
Message 8 of 26
Pylonbob
Hi, thanks for your swift reply, if I can get to grips with how to do this it will be a great help as I sometimes want to alter other mesh files that up to now I haven't been able to do. Thanks in advance, Bob.
Message 9 of 26
TrippyLighting
Here is a video explaining the process:
(view in My Videos)
Message 10 of 26
Pylonbob
Hi, thanks for replying, I copied your video to the letter and the attached file is what I ended up with. Although the end result is good it's not really what I wanted. What I am trying to achieve is two eye holes, the one that is there on the model I have sent and one to the right. they need to be 12.05mm in diameter and 0.5mm deep so that I can glue two 3d printed eyes in to the holes. When I slice the head I have a concave hole that really if possible needs to be a flat recess. As I said before the hole command allows me to roughly do that but as the model face is not flat some parts of the recess end up slightly deeper than others. Regards, Bob.
Message 11 of 26
TrippyLighting
The purpose of my video was NOT to do exactly what you need but to convey the concept of how  YOU can complete YOUR work. I find your explanations somewhat ambiguous. Please create a pencil/paper sketch of how a cross-section of that recessed glued-in eye in the main body would look like. Snap a picture of it and embed it into a post (you can drag an image from a folder right into a post).
Then I can show you how It can be modeled.
Message 12 of 26
rex_wrx
I wish you would just answer the question.
Can you convert a MESH to Solid useing the personal version of Fusion?
Message 13 of 26
TheCADWhisperer
@rex_wrx
Yes.
Message 14 of 26
TrippyLighting
Or you could just insert a mesh and try it ?
Message 15 of 26
rex_wrx
OK, I will be calm.
All of the YouTube videos show an additional tool area that I do not see in the FREE version of Fusion.
I am aware that it is a "limited" product.
I would like details useing the FREE version to convert a mesh object to a solid object.
Thank you.
Message 16 of 26
TheCADWhisperer
@rex_wrx
What videos? Provide links for reference.
What tools are you not seeing?
Or Attach your mesh file here for demonstration using your actual geometry.
Message 17 of 26
rex_wrx
Thank you for the reply.
Attached is 1 of the files I want to change from mesh to solid.
Message 18 of 26
TrippyLighting
The only option in the free subscription is the Faceted" version:
Depending on the mesh, however that might not result in what you want, or might not work at all . Not all meshes are created equally.
Message 19 of 26
TheCADWhisperer
Message 2 (the first Reply in this discussion) shows how to convert this to a Solid Body.
Message 20 of 26
rex_wrx
TheCADWhisperer,
Thank you for your reply,
However: The tool shown is NOT part of the FREE (Personal) version of the software.
