convert a circular array of points to holes
widpyro
widpyro
I have created a circular array of points and want to convert the points to holes. I started my sketch with a .15 hole but the circular pattern creates points not holes. There are a lot of holes. What is an easy way to convert all of them to .15 holes?
TheCADWhisperer
It would be better to create one (or 5 in this case) Hole feature and then pattern the Feature.
First thing I notice is that your sketch doesn't have any dimensions and when I add the missing dimensions they do not make logical sense (close to 6.5, but not 6.5).
Then I notice that you duplicated dimensions for the circles rather than simply use Equal (=) constraint.
This way you would only have one diameter dimension to edit if needed.
I also noticed that your square (Rectangle) is not constrained to the Origin.
If you had use Centerpoint Rectangle this would have been automatic.
See Attached file...
g-andresen
just create one instance on a circle > extrude it and create a circular pattern in solid mode
Check the diameters!
günther
