Control Surface transition with sketch
First post here so apologise if this has been covered before, but my searching has found the answer.
I would like to create T-Spline surfaces but constrained to existing sketches or geometry. By that I mean imagine a cup/mug with a handle. If the point at which the handle leaves the cup was a shape driven by a sketch, could be a perfect circle or something more complicated and same would apply where the handle returns and meets the cup again, but I can manipulate the surface in between. Another example would be a biscuit tin with straight vertical sides that are driven by a sketch (straight lines and raduis's) but I wanted to model a more organic lid bit maintain and control the connection to the side geometry.
Hope those descriptions get across how I would like to control the connection from a geometric shape to an organic surface.
Thanks for any help
Simon
TrippyLighting
If you could post an example design of what you are envisioning, even as a scnned or photographed hand kech, that would go a long way in getting this anwered.
I think I understand what you mean but it would be better explained on a real example.
Realised I have made a typo mistake in the first line of the original post which looks like I have found an answer! Not the case I am afraid, still looking for advise.
Regards Simon
innovatenate
Autodesk Support
Autodesk Support
Below is a screencast with some suggestions that may help.
Hope that helps! Let us know if you have any questions.
Nathan Chandler
Principal Specialist
Hi Nathan,
Awsome reply, that certainly was far more than I had expected. Thank you, I will practice those techniques and I am sure it is going to get me much closer.  Thanks again.
Simon
