Continual "Not Responding" during Sketching
I was getting random crashing with an earlier drawing but now im stuck on a drawing that wont let me draw a line I need. I attached an image of the line I am trying to make  but keeps crashing when the line comes in contact with any of the surfaces in my drawing and shows any . My system is a ryzen 1800x, 1080ti, 16gb ram and windows 10. I currently do not have an antivirus which I noticed others were having issues with. I have also tried going into offline job statis. I tried Nvidia drivers (387.92) but did not solve the issue. I also attached the Diagnostics Data Log.
TrippyLighting
May be you can share your design so we can try to analyse is and see if the issue can be reproduced.
jeff_strater
This is a wild guess, but try turning off the "Auto Project Edges on Reference" setting in your preferences:
There is a bug that we are in the middle of fixing where this setting can cause crashes that might be related to what you are seeing.
Worth a try, at least.  But, yes, as @TrippyLighting says, we'd need to see your model to help any more than that.
Jeff
Jeff Strater
Engineering Director
Thanks Jeff that seemed to do the trick. It would lock up when I moved the line segment away from where I started the line and it would come into contact with another surface. I turned off auto project lines, started a line and moved my cursor all around with no lock, turned auto project back on and immediately locked after I started the same line again. Im a little new to this still so im not sure how to share my project. I would still like to post it so I can get more feedback. Thanks again
This appears to fix a similar or maybe same issue i am having.
When sketching a line Fusion hangs. It appears to be when an apparent snap point is highlighted on a certain part in my assembly. Here is a Screencast of it....
http://autode.sk/2ymqcxU
I tried turning off the Auto project edges on reference as you suggested and the Not Responding issue i was getting during a sketch is not happening now.
Troy
