Choose from different customizable content and insert your selection into your Fusion design. Easily change the parameters to make the inserted file (screw, nut, ...) personal, such it fits your needs. You can also save your presets or upload your own customizable content to share with others. While finished to set up the part as you want it, you can join it to existing JointOrigins or to other inserted files.
Here you can select a preset and insert the part. After insertion the preset will be applied. You can also change your preset at any time after insertion. If you want to add the same part again, simply insert it twice and then change the preset of the second part accordingly after insertion. You can later go to the Documents Content Tab and change the parameters and presets again.
The Documents Contents Tab displays a list containing all commponents of your active Fusion 360 document with the depending user parameters. If a component was previously inserted under the Insert Tab, you can change the presets here again. This will also work when you open your Fusion document the next time. A preset will automatically set all user parameters of a part. If you need changes or want to create a new preset to use later, you are welcome to change every parameter as you wish. If you inserted the same component twice, you will see here both components which might have different presets.
The Joints Tab is for creating Joints of the inserted components. You can multiply one component and add it to all selected JointOrigins or to all Occurrences of another component.
You can browse throught the available content on my website https://custom.hk-fs.de/. I try to add more content over time. If you miss a part please let me know and I will try my best to add it.
Currently I have 8 different parts with more than 1000 presets to chose from.
as of 26/02/2019
If you miss a part, please create an issue or message me. I will add it as soon as possible!
Use the Autodesk App Store links or try a manual installation. You only get the absolutely newest version with the manual installation. But the Add-In will also update itself to the newest available Version if you install from the Autodesk App Store. If something is not going well try the manual installation or ask me for help.
Windows 64 Version
Mac OS Version
Visit my Github
Thank you! Help me improve my Add-In by doing the Google Form Survey
Annnnd the best thing last: It is free!
This is awesome- thanks for sharing!
