contact set instability
Good Morning,
I have a contact set that doesn't want to behave properly.  Anytime I suppress, or enable/disable, the contact set, it inadvertently picks a different body than what was intended.  The same behavior happens when I open/close the file, save, edit, and even intermittently.   Please see attached screenshots for details.
Thank you.
Dave Blandino
(Windows 7, 64-bit, FUSION V2.0.5790)contact set pic-1.jpgcontact set pic-2.jpg
chrisplyler
Yup. The implementation of Contact Sets in F360 is pretty sketchy. If you can obtain your desired behavior with Joint Limits instead, as I suspect is the case in your scenario, you will be much better off.
