Message 1 of 11
- Mute
- Permalink
- Report
Question on removing construction line that is associated with each of the control splines. I attached the file as well. Each of those partial loops above and below the oblong holes you can see the squared off lines attached to each loop. When I open this is manufacture and attempt to lay out the paths to burn I select the loop but it selects each of those squared off construction lines as well.. and thus it thinks I want to burn the construction line out too. I've tried removing the construction line but then the loop becomes distorted.
Any help would be much appreciated.
