Construction geometry: changing the custom keyboard shortcut
Hello folks,
I'm still learning Fusion, so bear with me here. I come from a background of multiple CAD and CAM systems, and I've always found some way to make my "toggle construction geometry" to have the shortcut set as the letter "Q"
I've seen you can change shortcuts if the command is in the menu bars, but this isn't in a menu bar, it's already hardwired into the system as "X". Is there any way to change this? Maybe I'm just not seeing where it's supposed to be in the drop down commands, I only see it when I right click on an entity or on the right side panel.
It seems trivial, but I'd love to A: not have to change my own muscle memory to match a CAD program I'm just barely learning and B: go back and change all the other systems I use on a daily basis to match.
Thanks for the assistance!
