Construction/3D points disappear
Message 1 of 8
This is not really a big deal, but thought I would report it.  I've noticed for points that are created as construction points (I specifically used Point at Vertex), and as Include 3D Geometry, they tend to disappear for certain view perspectives when multiple points are somewhat nearing overlapping each other.  Attached is an example.
Thanks!
Jesse
Replies (7)
Message 2 of 8
I'm going to upload a screencast in a second
Message 3 of 8
Here is a screencast of the disappearing construction points:
https://screencast.autodesk.com/main/details/02ef1e3d-dff5-4ecb-9367-e4c0fe28c3fb
And the same for Include 3D Geometry points:
https://screencast.autodesk.com/main/details/bc8aa49f-b289-4021-9e85-ff0829329158
Message 4 of 8
Ok I guess it's a scale issue bug.  In the following screencast it's seen that when at a scale where the grid is larger than your drawing, everything works fine, but points (including regular sketch points) start disappearing for certain views, and gets progressively worse, the larger the distance between sketch planes, especially when significantly greater than the grid scale (which from what I can tell is not currently adjustable).  So I guess a work around for now is to just scale down a model so everything fits comfortably within the grid.
https://screencast.autodesk.com/main/details/ac3d6e27-8d98-44a9-a350-52bf8147b5ef
Jesse
Message 5 of 8
Wow I guess it's not a bug after all!  I was just only working with points and dimensions, so the grid had no way of knowing to enlarge itself, as it would if I had but even used sketch lines.
All is well 😉
Jesse
Message 6 of 8
Maowen_Zhang
Thanks a lot for catching this issue! I just tried, the attached f3d file and screencast are very easy to check the issue, I reported as FUS-19282 in our tracking system, thanks!
Lori Zhang (Fusion Development)
Message 7 of 8
I was thinking about describing the precise identical problem. included 3d points disappear.
Is there now any explanation to the behaviour and the ticket?
Message 8 of 8
Phil.E
@Anonymous
Your reply is posted here:
https://forums.autodesk.com/t5/fusion-360-design-validate/construction-3d-points-disappear/m-p/7869029/highlight/false#M153575
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
