Construct in 3D with 45deg bevel?
- Mute
- Permalink
- Report
I got a very simple problem (I guess) but it is beyond my knowledge.
I want to create a model, that has an indentation/bevel with 45deg angles, but I can't figure it out.
I can almost manage with 3D sketches - patch - stitch - shell but feels like it has to be an easier way.
I got a component with a opening in it. So I know the outside dimensions.
I created the above model just to show what I'm trying to do, but it's wrong. The indentation (hope that is the right name) is the same heigth (check next picture)
More visible here, but the blue line marked, I want the hole that is below and above the indentation to be with a 45deg plate. Making the marked line needing to be shorter.
Not sure If my need is clear, but tried just to draw plates (extruded sketches) and join them all as a large component, but also feels "messy".
This needs to be 3D printed, so also have to have absolute control of the thickness, to match nozzle size and layer hight.
Please help a noob 😞
