Constraints on multiple items
Is there a way to apply a constraint to multiple selected items in a sketch similtaniously?
As far as I can see it is only possible to apply a constraint between two items at the moment. I have always found it very useful to be able to select larger numbers of items to apply some constraints like equals where I want spacings to be calculated for me, or colinear where I want to bring various items in line.
It seems daft that I have to select each pair of items one by one and add the constraint at the moment so I'm hoping there is a solution I have missed.
Thanks in advance.
Not at the moment, but hopefully this will be supported soon.  At the moment there is a different approach you could take. without having any entities selected in your sketch, first click on the constraint type you with to apply. Then click on pairs of sketch entities and the constraint type will remain active, so you can keep clicking pairs.
Hope that helps,
Niels
